Links en inglés con tutoriales de modificaciones
Dante
Moto:: Speed Triple 1050
Mensaje por Dante »
Buscando en la red, me he encontrado con esto en el triumphrat:
http://www.triumphrat.net/twins-technic ... links.html
Copio el contenido de su post citando la fuente para que no haya problemas:
londonBonnie wrote:
useful old links
Hope the mods don't mind me posting this...from the old wiki
Suck
Polaris Bellmouth (Rexa) - http://www.triumphrat.net/showthread.php?t=25442
Restrictor Plate removal (keef) - http://www.triumphrat.net/showthread.php?t=33758
Airbox Removal (keef) - http://www.triumphrat.net/showthread...8973&page=3#27 or http://www.triumphrat.net/showpost.p...8&postcount=27
Airbox Removal (psasack) - http://www.triumphrat.net/showthread.php?t=40034
Airbox Removal (markbvt) - http://www.triumphrat.net/showthread.php?t=54862
Airbox Removal (Blackjack) - http://www.triumphrat.net/showthread.php?t=48715
D shaped mixture screw tool (dazco & sheepdog) - http://www.triumphrat.net/showthread.php?t=32123
DIY Choke Knob (Gray Mitchell, et. al.) - http://www.triumphrat.net/showthread.php?t=47714 and again (greyplaque, et. al.) - http://www.triumphrat.net/showthread.php?t=47681
NOS install - http://www.triumphrat.net/showthread.php?t=51429 and finished (bonnieblackinfl) - http://www.triumphrat.net/showthread.php?t=51497
Billet manifolds & velocity stacks (robnobrakes) - http://www.triumphrat.net/showthread.php?t=59804
Bang
Exhaust cam mod comparison (SCCTrim) - http://www.triumphrat.net/showthread.php?t=41130 and follow up with HSRs - http://www.triumphrat.net/showthread.php?t=42585
Thunderbike dyno - http://www.triumphrat.net/showthread.php?t=25919 and torque (RCV) - http://www.triumphrat.net/showthread.php?t=26210
BB prelude (sweatmachine) - http://www.triumphrat.net/showthread.php?t=48078 and follow up - http://www.triumphrat.net/showthread.php?t=49481
1200cc stroked crank (bonnieblackinfl) - http://www.triumphrat.net/showthread.php?t=59299 and pistons & jugs - http://www.triumphrat.net/showthread.php?t=58063
Blow
2into1 pipes (rodburner) - http://www.triumphrat.net/showthread.php?t=45595
Bafflectomy (kdlutes) - http://www.triumphrat.net/showthread.php?t=13595
Muffler & Centrestand mods (Loxpump) - http://www.triumphrat.net/showthread.php?t=38984
Thruxton exhaust drilling (thruxtonone) - http://www.triumphrat.net/showthread.php?t=23593&=#10
predators vs TORs (robnobrakes) - http://www.triumphrat.net/showthread.php?t=44168
Wizz
Green clutch springs (bonnieblackinfl) - http://www.triumphrat.net/showthread.php?t=51652
sprocket changing (ohiorider) - http://www.triumphrat.net/showthread.php?t=40273&=#3
sprocket cover mod (Caffeinated) - http://www.triumphrat.net/showthread.php?t=53360
ditto (via bsmith222) - http://www.triumphrat.net/showthread.php?t=59165
ditto light weight (robnobrakes) - http://www.triumphrat.net/showthread.php?t=56672
ditto (mr_badda_bing) - http://www.triumphrat.net/showthread.php?t=58347
Scottoiler on scrambler (johnyC) - http://www.triumphrat.net/showthread.php?t=27974
Skeletonized sprocket guard (JG) - http://www.triumphrat.net/showthread.php?t=38082
Slap
Foot control mod (bennybmn) - http://www.triumphrat.net/showthread.php?t=32819
Drilled rear brake lever (robnobrakes) - http://www.triumphrat.net/showthread.php?t=56520
Mirror extensions (PCRider) - http://www.triumphrat.net/showthread.php?t=24489
Bar end mirror mod (ratcat & keef) - http://www.triumphrat.net/showthread.php?t=40661
air horn install (SCCTrim) - http://www.triumphrat.net/showthread.php?t=47395
Horn relocation (TLC & Mancha) - http://www.triumphrat.net/showthread.php?t=54050
Regulator relocation (thrux-to-up) - http://www.triumphrat.net/showthread.php?t=54330
Garage door remote mod (Ridge) - http://www.triumphrat.net/showthread.php?t=32342
Flap
Bar comparison (bonafide) - http://www.triumphrat.net/showthread.php?t=46984&=#14
Alternative thrux 41mm clip-ons (bonnieblackinfl) - http://www.triumphrat.net/showthread.php?t=48376
Susp
Fork boot changing (keef) - http://www.triumphrat.net/showthread.php?t=39420&=#2
ditto (bobmig) - http://www.triumphrat.net/showthread.php?t=13631
progressive springs (keef) - http://www.triumphrat.net/showthread.php?t=39596
f3 fork mod (SCCTrim) - http://www.triumphrat.net/showthread.php?t=46560
daytona forks (tommer) - http://www.triumphrat.net/showthread.php?t=48023
adjustable preload (badrufus) - http://www.triumphrat.net/showthread.php?t=40027&=#7
shroud removal (rodburner) - http://www.triumphrat.net/showthread.php?t=40758
fork spring changing without removing stanshions (markbvt) - http://www.triumphrat.net/showthread.php?t=42251&=#6
Brass
home made skidplate (Graymitchel & greyplague) - http://www.triumphrat.net/showthread.php?t=47950
ditto (Furbags) - http://www.triumphrat.net/showthread.php?t=20923
oil cooler stone guard (cafecruzin & robnobrakes) - http://www.triumphrat.net/showthread.php?t=56074&=#8
Tool carrier for NARK (CYNCRZR) - http://www.triumphrat.net/showthread.php?t=45118
ditto (keef) - http://www.triumphrat.net/showthread.php?t=47234
Thruxton numberboards (robnobrakes) - http://www.triumphrat.net/showthread.php?t=54454 - http://www.triumphrat.net/showthread.php?t=54899
Bobbing fenders & fly screen (D9) - http://www.triumphrat.net/showthread.php?t=36259
Bobbing fenders (Loxpump & D9) - http://www.triumphrat.net/showthread.php?t=37582
ditto (Werner, et. al.) - http://www.triumphrat.net/showthread.php?t=41022
dart flyscreen brackets (vertwrks) - http://www.triumphrat.net/showthread.php?t=24533
DIY dart flyscreen (xardoz) - http://www.triumphrat.net/showthread.php?t=57320
saddle bag mounts (JT via wonderdog) - http://www.triumphrat.net/showthread.php?t=27174
ditto (Copper) - http://www.triumphrat.net/showthread.php?t=31283 and update (Ridge) - http://www.triumphrat.net/showthread.php?t=56020
ditto (dazco) - http://www.triumphrat.net/showthread.php?t=58378
Highway bars (bonnevillebilly) - http://www.triumphrat.net/showthread.php?t=37211
ditto (modre) - http://www.triumphrat.net/showthread.php?t=33345&=#8
heelplate mod (thruxtonone) - http://www.triumphrat.net/showthread.php?t=46793
ditto (cafecruzin) - http://www.triumphrat.net/showthread.php?t=59560
Heelplate mod (robnobrakes) - http://www.triumphrat.net/showthread.php?t=56074
stand mod for D&D pipes (Toyanvil) - http://www.triumphrat.net/showthread.php?t=59379
fuel cap & spacers (tham) - http://www.triumphrat.net/showthread.php?t=57559
Thruxton sidecar combo (oregonthruxton & evalu8or) - http://www.triumphrat.net/showthread.php?t=40501 and fixings (oregonthruxton) - http://www.triumphrat.net/showthread.php?t=53307
guzzi style thruxton (via streetsailor) - http://www.triumphrat.net/showthread.php?t=59393
Hinckley speed twin (Rip) - http://www.triumphrat.net/showthread.php?t=53362
Hinckley Tritons (via keef & Big Rick) - http://www.triumphrat.net/showthread.php?t=54878
Air dam on bonnie - http://www.triumphrat.net/showthread.php?t=60967
aid dam animation (Ridge) - http://www.triumphrat.net/showthread.php?t=56141&=#5
Ass
Seat & rear fender mods (rodburner) - http://www.triumphrat.net/showthread.php?t=60973 - http://www.triumphrat.net/showthread.php?t=27718
Thruxton Race Seat & Tank (Mancha) - http://www.triumphrat.net/showthread.php?t=27375
Sportster seat onto bonnie (rodburner) - http://www.triumphrat.net/showthread.php?t=40758&=#8
Shortened Rear Frame (rodburner) - http://www.triumphrat.net/showthread.php?t=43412
Sissy bar riser (bonnevillebilly) - http://www.triumphrat.net/showthread.php?t=32447
ditto (dardoonk) - http://www.triumphrat.net/showthread.php?t=35337
seat and bar clamp mod (ozbon & Copper) - http://www.triumphrat.net/showthread.php?t=23834
scrambled thruxton (Bigdogs) - http://www.triumphrat.net/showthread.php?t=56067
solo sprung saddle on T100 (Motorboy) - http://www.triumphrat.net/showthread.php?t=53561
tractor seat mod (modre) - http://www.triumphrat.net/showthread.php?t=54513
Tweaks
Heli coil (sweatmachine) http://www.triumphrat.net/showthread.php?t=59856
carb tuning tools (badrufus) - http://www.triumphrat.net/showthread.php?t=56245
ditto (Duckman) - http://www.triumphrat.net/showthread.php?t=60061&=#7
crank weld (tcb) - http://www.triumphrat.net/showthread.php?t=56329
clutch replacement (merlin & greyplague) - http://www.triumphrat.net/showthread.php?t=52941
cam locking pin (sweatmachine & dazco) - http://www.triumphrat.net/showthread.php?t=44052 dimensions (Bassnote) - http://www.triumphrat.net/showthread.php?t=54579
carb balancing (airneads.org) - http://www.airheads.org/content/view/183/49/
ditto (ohiorider) - http://www.triumphrat.net/showthread...2913&page=2#16 and pictures (TCL) - http://www.triumphrat.net/showthread.php?t=51772
sprocket changing (ohiorider) - http://www.triumphrat.net/showthread.php?t=56723&=#3
polishing tips (jkieler) - http://www.triumphrat.net/showthread.php?t=48955&=#7
oil filter dissection (grayghost) - http://www.triumphrat.net/showthread.php?t=53292
Muffler Autopsy (Loxpump) - http://www.triumphrat.net/showthread.php?t=38422
Triple tree polishing (dazco) - http://www.triumphrat.net/showthread.php?t=23456&=#3
Dyno HSR (SCCTrim) - http://www.triumphrat.net/showthread.php?t=42585
Dyno 790 HSR (bonnieblackinfl) - http://www.triumphrat.net/showthread.php?t=47312
Dyno (robnobrakes) - http://www.triumphrat.net/showthread.php?t=39729
Zap
Lowered headlamp and gauges (sweatmachine) - http://www.triumphrat.net/showthread.php?t=39154
ditto (rodburner, sweatmachine & D9) - http://www.triumphrat.net/showthread.php?t=46338
Headlamp mount (rodburner) - http://www.triumphrat.net/showthread.php?t=49288
aftermarket tach install (LS1 & bonnevillebilly) - http://www.triumphrat.net/showthread.php?t=46211
oil pressure gauge (thrux-ton-up & bennybmn) - http://www.triumphrat.net/showthread.php?t=40466
oil pressure gauge (SCCTrim) - http://www.triumphrat.net/showthread.php?t=50700
oil pressure guage (bonnevillebilly) - http://www.triumphrat.net/showthread.php?t=56138
lowered gauges (caspianthruxton, sweatmachine, Werner, et. al) - http://www.triumphrat.net/showthread.php?t=40465
custom mini gauge brackets (D9) - http://www.triumphrat.net/showthread.php?t=42443
ditto plus relocated ignition (D9) - http://www.triumphrat.net/showthread.php?t=44276 and updated versions - http://www.triumphrat.net/showthread.php?t=57199 and lay-flat gauges - http://www.triumphrat.net/showthread.php?t=58202 and finally some silliness - http://www.triumphrat.net/showthread.php?t=45332&=#8
Clock mounts (Loxpump, D9 & bonnevillebilly) - http://www.triumphrat.net/showthread.php?t=47685
Home made instrument buckets (Oldskoolfool) - http://www.triumphrat.net/showthread.php?t=46621
ditto plus extras (adamoverdrive) - http://www.triumphrat.net/showthread.php?t=32449
let there be more light (stine) - http://www.triumphrat.net/showthread.php?t=27349
Indicator stem shortening (D9) - http://www.triumphrat.net/showthread.php?t=39703
Fix for hard to see indicators on cruisers (dazco) - http://www.triumphrat.net/showthread.php?t=21948
Turn signal mod (thruxtonone) - http://www.triumphrat.net/showthread.php?t=46796
Turn signal mod - front - http://www.triumphrat.net/showthread.php?t=56614&=#8 - rear (Toyanvil) - http://www.triumphrat.net/showthread.php?t=53057
turn signal mod (TCL) - http://www.triumphrat.net/showthread.php?t=54047
Running lights (n578md) - http://www.triumphrat.net/showthread.php?t=43588
D9 gauge bracket animation (Ridge) - http://www.triumphrat.net/showthread.php?t=58659
londonBonnie
hackney
blkBonnie/diynark/40/140/3t/togas/
Yo al menos me he vuelto loco al verlo. Si alguien no sabe inglés y busca algo en especial, los que sabemos podríamos estar al tanto y usar este post para ayudar. La verdad es que los tutoriales que he visto vienen bien provistos de fotos.
londonBonnie, BIG :XX: :XX: :XX: :XX: if you ever read we copied your useful link!!!!!!
TOPOPACO in memoriam
tatoamerica
Moto:: Triumph america 09
Re: Links en inglés con tutoriales de modificaciones
Mensaje por tatoamerica »
:o :o :o :o :o
:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
Un diez para ti
La única y verdadera ley es aquella que nos conduce a la libertad
Dante
Mensaje por Dante »
No tío.... un diez para londonBonnie :lol:
JOAVEL
Mensaje por JOAVEL »
Muy bueno Dante, gracias por compartir :XX:
Brio
Moto:: Brio 1961 y Thruxton
Mensaje por Brio »
Muchas gracias :XX:
tatoamerica
Dante escribió:No tío.... un diez para londonBonnie :lol:
bueno pues mandale pa londres su parte y tu que date la tuya :XX:
Dante
Mensaje por Dante »
:wink: :alcoholico:
pakomoraira
Moto:: Thunderbird
Mensaje por pakomoraira »
:win: :win: :win: :win: :win: :win:
AMUNT TRIUMPH - BE TRIUMPH MY FRIEND
lorbruno
Mensaje por lorbruno »
muy bueno!! :ala:
"Vale la pena pelear por lo que vale la pena poseer."
schnelomedi
Mensaje por schnelomedi »
Hola, sería muy interesante que tradujera en el idioma de CERVANTES para mi y seguro para muchos otros miembros de este foro seria GENIAL !
Saludos :tregua: .
LordIronBar
Moto:: Thruxton 900
Mensaje por LordIronBar »
Buen enlace
ImagenImagenImagenImagenImagen
muy bueno :XX:
